<?xml version="1.0"?>
<api>
  <error code="unknown_action" info="Unrecognized value for parameter &#039;action&#039;: https://u.to/0R5TIg" xml:space="preserve">
  **                      This is an auto-generated MediaWiki API documentation page                      **
  **                                     Documentation and Examples:                                      **
  **                                  https://www.mediawiki.org/wiki/API                                  **
  Status:                All features shown on this page should be working, but the API
                         is still in active development, and may change at any time.
                         Make sure to monitor our mailing list for any updates
  Erroneous requests:    When erroneous requests are sent to the API, a HTTP header will be sent
                         with the key "MediaWiki-API-Error" and then both the value of the
                         header and the error code sent back will be set to the same value
                         In the case of an invalid action being passed, these will have a value
                         of "unknown_action"
                         For more information see https://www.mediawiki.org/wiki/API:Errors_and_warnings
  Documentation:         https://www.mediawiki.org/wiki/API:Main_page
  FAQ                    https://www.mediawiki.org/wiki/API:FAQ
  Mailing list:          https://lists.wikimedia.org/mailman/listinfo/mediawiki-api
  Api Announcements:     https://lists.wikimedia.org/mailman/listinfo/mediawiki-api-announce
  Bugs & Requests:       https://bugzilla.wikimedia.org/buglist.cgi?component=API&bug_status=NEW&bug_status=ASSIGNED&bug_status=REOPENED&order=bugs.delta_ts
Parameters:
  format              - The format of the output
                        One value: json, jsonfm, php, phpfm, wddx, wddxfm, xml, xmlfm, yaml, yamlfm, rawfm, txt, txtfm, dbg, dbgfm,
                            dump, dumpfm
                        Default: xmlfm
  action              - What action you would like to perform. See below for module help
                        One value: login, logout, query, expandtemplates, parse, opensearch, feedcontributions, feedwatchlist, help,
                            paraminfo, rsd, compare, purge, rollback, delete, undelete, protect, block, unblock, move, edit,
                            upload, filerevert, emailuser, watch, patrol, import, userrights
                        Default: help
  version             - When showing help, include version for each module
  maxlag              - Maximum lag can be used when MediaWiki is installed on a database replicated cluster.
                        To save actions causing any more site replication lag, this parameter can make the client
                        wait until the replication lag is less than the specified value.
                        In case of a replag error, a HTTP 503 error is returned, with the message like
                        "Waiting for $host: $lag seconds lagged\n".
                        See https://www.mediawiki.org/wiki/Manual:Maxlag_parameter for more information
  smaxage             - Set the s-maxage header to this many seconds. Errors are never cached
                        Default: 0
  maxage              - Set the max-age header to this many seconds. Errors are never cached
                        Default: 0
  requestid           - Request ID to distinguish requests. This will just be output back to you
  servedby            - Include the hostname that served the request in the results. Unconditionally shown on error
*** *** *** *** *** *** *** *** *** *** *** *** *** ***  Modules  *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* action=login (lg) *
  Log in and get the authentication tokens.
  In the event of a successful log-in, a cookie will be attached
  to your session. In the event of a failed log-in, you will not
  be able to attempt another log-in through this method for 5 seconds.
  This is to prevent password guessing by automated password crackers
This module only accepts POST requests
Parameters:
  lgname              - User Name
  lgpassword          - Password
  lgdomain            - Domain (optional)
  lgtoken             - Login token obtained in first request
Example:
  api.php?action=login&lgname=user&lgpassword=password
Help page:
  https://www.mediawiki.org/wiki/API:Login
* action=logout *
  Log out and clear session data
Example:
  Log the current user out:
    api.php?action=logout
Help page:
  https://www.mediawiki.org/wiki/API:Logout
* action=query *
  Query API module allows applications to get needed pieces of data from the MediaWiki databases,
  and is loosely based on the old query.php interface.
  All data modifications will first have to use query to acquire a token to prevent abuse from malicious sites
This module requires read rights
Parameters:
  titles              - A list of titles to work on
  pageids             - A list of page IDs to work on
                        Maximum number of values 50 (500 for bots)
  revids              - A list of revision IDs to work on
  prop                - Which properties to get for the titles/revisions/pageids. Module help is available below
                        Values (separate with '|'): info, revisions, links, iwlinks, langlinks, images, imageinfo, stashimageinfo, templates,
                            categories, extlinks, categoryinfo, duplicatefiles, pageprops
  list                - Which lists to get. Module help is available below
                        Values (separate with '|'): allimages, allpages, alllinks, allcategories, allusers, backlinks, blocks, categorymembers,
                            deletedrevs, embeddedin, filearchive, imageusage, iwbacklinks, langbacklinks, logevents,
                            recentchanges, search, tags, usercontribs, watchlist, watchlistraw, exturlusage, users, random,
                            protectedtitles, querypage
  meta                - Which metadata to get about the site. Module help is available below
                        Values (separate with '|'): siteinfo, userinfo, allmessages
  generator           - Use the output of a list as the input for other prop/list/meta items
                        NOTE: generator parameter names must be prefixed with a 'g', see examples
                        One value: links, images, templates, categories, duplicatefiles, allimages, allpages, alllinks, allcategories,
                            backlinks, categorymembers, embeddedin, imageusage, iwbacklinks, langbacklinks, recentchanges,
                            search, watchlist, watchlistraw, exturlusage, random, protectedtitles, querypage
  redirects           - Automatically resolve redirects
  converttitles       - Convert titles to other variants if necessary. Only works if the wiki's content language supports variant conversion.
                        Languages that support variant conversion include gan, iu, kk, ku, shi, sr, tg, zh
  indexpageids        - Include an additional pageids section listing all returned page IDs
  export              - Export the current revisions of all given or generated pages
  exportnowrap        - Return the export XML without wrapping it in an XML result (same format as Special:Export). Can only be used with export
  iwurl               - Whether to get the full URL if the title is an interwiki link
Examples:
  api.php?action=query&prop=revisions&meta=siteinfo&titles=Main%20Page&rvprop=user|comment
  api.php?action=query&generator=allpages&gapprefix=API/&prop=revisions
Help pages:
  https://www.mediawiki.org/wiki/API:Meta
  https://www.mediawiki.org/wiki/API:Properties
  https://www.mediawiki.org/wiki/API:Lists
--- --- --- --- --- --- --- --- --- --- --- ---  Query: Prop  --- --- --- --- --- --- --- --- --- --- --- ---
* prop=info (in) *
  Get basic page information such as namespace, title, last touched date, ...
Parameters:
  inprop              - Which additional properties to get:
                         protection   - List the protection level of each page
                         talkid       - The page ID of the talk page for each non-talk page
                         watched      - List the watched status of each page
                         subjectid    - The page ID of the parent page for each talk page
                         url          - Gives a full URL to the page, and also an edit URL
                         readable     - Whether the user can read this page
                         preload      - Gives the text returned by EditFormPreloadText
                         displaytitle - Gives the way the page title is actually displayed
                        Values (separate with '|'): protection, talkid, watched, subjectid, url, readable, preload, displaytitle
  intoken             - Request a token to perform a data-modifying action on a page
                        Values (separate with '|'): edit, delete, protect, move, block, unblock, email, import, watch
  incontinue          - When more results are available, use this to continue
Examples:
  api.php?action=query&prop=info&titles=Main%20Page
  api.php?action=query&prop=info&inprop=protection&titles=Main%20Page
Help page:
  https://www.mediawiki.org/wiki/API:Properties#info_.2F_in
* prop=revisions (rv) *
  Get revision information
  May be used in several ways:
   1) Get data about a set of pages (last revision), by setting titles or pageids parameter
   2) Get revisions for one given page, by using titles/pageids with start/end/limit params
   3) Get data about a set of revisions by setting their IDs with revids parameter
  All parameters marked as (enum) may only be used with a single page (#2)
Parameters:
  rvprop              - Which properties to get for each revision:
                         ids            - The ID of the revision
                         flags          - Revision flags (minor)
                         timestamp      - The timestamp of the revision
                         user           - User that made the revision
                         userid         - User id of revision creator
                         size           - Length (bytes) of the revision
                         sha1           - SHA-1 (base 16) of the revision
                         comment        - Comment by the user for revision
                         parsedcomment  - Parsed comment by the user for the revision
                         content        - Text of the revision
                         tags           - Tags for the revision
                        Values (separate with '|'): ids, flags, timestamp, user, userid, size, sha1, comment, parsedcomment, content, tags
                        Default: ids|timestamp|flags|comment|user
  rvlimit             - Limit how many revisions will be returned (enum)
                        No more than 500 (5000 for bots) allowed
  rvstartid           - From which revision id to start enumeration (enum)
  rvendid             - Stop revision enumeration on this revid (enum)
  rvstart             - From which revision timestamp to start enumeration (enum)
  rvend               - Enumerate up to this timestamp (enum)
  rvdir               - In which direction to enumerate (enum)
                         newer          - List oldest first. Note: rvstart has to be before rvend.
                         older          - List newest first (default). Note: rvstart has to be later than rvend.
                        One value: newer, older
                        Default: older
  rvuser              - Only include revisions made by user (enum)
  rvexcludeuser       - Exclude revisions made by user (enum)
  rvtag               - Only list revisions tagged with this tag
  rvexpandtemplates   - Expand templates in revision content
  rvgeneratexml       - Generate XML parse tree for revision content
  rvparse             - Parse revision content. For performance reasons if this option is used, rvlimit is enforced to 1.
  rvsection           - Only retrieve the content of this section number
  rvtoken             - Which tokens to obtain for each revision
                        Values (separate with '|'): rollback
  rvcontinue          - When more results are available, use this to continue
  rvdiffto            - Revision ID to diff each revision to.
                        Use "prev", "next" and "cur" for the previous, next and current revision respectively
  rvdifftotext        - Text to diff each revision to. Only diffs a limited number of revisions.
                        Overrides rvdiffto. If rvsection is set, only that section will be diffed against this text
Examples:
  Get data with content for the last revision of titles "API" and "Main Page"
    api.php?action=query&prop=revisions&titles=API|Main%20Page&rvprop=timestamp|user|comment|content
  Get last 5 revisions of the "Main Page"
    api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment
  Get first 5 revisions of the "Main Page"
    api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvdir=newer
  Get first 5 revisions of the "Main Page" made after 2006-05-01
    api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvdir=newer&rvstart=20060501000000
  Get first 5 revisions of the "Main Page" that were not made made by anonymous user "127.0.0.1"
    api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvexcludeuser=127.0.0.1
  Get first 5 revisions of the "Main Page" that were made by the user "MediaWiki default"
    api.php?action=query&prop=revisions&titles=Main%20Page&rvlimit=5&rvprop=timestamp|user|comment&rvuser=MediaWiki%20default
Help page:
  https://www.mediawiki.org/wiki/API:Properties#revisions_.2F_rv
* prop=links (pl) *
  Returns all links from the given page(s)
Parameters:
  plnamespace         - Show links in this namespace(s) only
                        Values (separate with '|'): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
  pllimit             - How many links to return
                        Default: 10
  plcontinue          - When more results are available, use this to continue
  pltitles            - Only list links to these titles. Useful for checking whether a certain page links to a certain title.
  pldir               - The direction in which to list
                        One value: ascending, descending
                        Default: ascending
Examples:
  Get links from the [[Main Page]]::
    api.php?action=query&prop=links&titles=Main%20Page
  Get information about the link pages in the [[Main Page]]::
    api.php?action=query&generator=links&titles=Main%20Page&prop=info
  Get links from the Main Page in the User and Template namespaces::
    api.php?action=query&prop=links&titles=Main%20Page&plnamespace=2|10
Help page:
  https://www.mediawiki.org/wiki/API:Properties#links_.2F_pl
Generator:
  This module may be used as a generator
* prop=iwlinks (iw) *
  Returns all interwiki links from the given page(s)
Parameters:
  iwlimit             - How many interwiki links to return
                        Default: 10
  iwcontinue          - When more results are available, use this to continue
  iwprefix            - Prefix for the interwiki
  iwtitle             - Interwiki link to search for. Must be used with iwprefix
  iwdir               - The direction in which to list
                        Default: ascending
Example:
  Get interwiki links from the [[Main Page]]:
    api.php?action=query&prop=iwlinks&titles=Main%20Page
* prop=langlinks (ll) *
  Returns all interlanguage links from the given page(s)
Parameters:
  lllimit             - How many langlinks to return
                        Default: 10
  llcontinue          - When more results are available, use this to continue
  llurl               - Whether to get the full URL
  lllang              - Language code
  lltitle             - Link to search for. Must be used with lllang
  lldir               - The direction in which to list
                        Default: ascending
Example:
  Get interlanguage links from the [[Main Page]]:
    api.php?action=query&prop=langlinks&titles=Main%20Page&redirects=
Help page:
  https://www.mediawiki.org/wiki/API:Properties#langlinks_.2F_ll
* prop=images (im) *
  Returns all images contained on the given page(s)
Parameters:
  imlimit             - How many images to return
                        Default: 10
  imcontinue          - When more results are available, use this to continue
  imimages            - Only list these images. Useful for checking whether a certain page has a certain Image.
  imdir               - The direction in which to list
                        Default: ascending
Examples:
  Get a list of images used in the [[Main Page]]:
    api.php?action=query&prop=images&titles=Main%20Page
  Get information about all images used in the [[Main Page]]:
    api.php?action=query&generator=images&titles=Main%20Page&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Properties#images_.2F_im
Generator:
* prop=imageinfo (ii) *
  Returns image information and upload history
Parameters:
  iiprop              - What image information to get:
                         timestamp     - Adds timestamp for the uploaded version
                         user          - Adds the user who uploaded the image version
                         userid        - Add the user ID that uploaded the image version
                         comment       - Comment on the version
                         parsedcomment - Parse the comment on the version
                         url           - Gives URL to the image and the description page
                         size          - Adds the size of the image in bytes and the height, width and page count (if applicable)
                         dimensions    - Alias for size
                         sha1          - Adds SHA-1 hash for the image
                         mime          - Adds MIME type of the image
                         thumbmime     - Adds MIME type of the image thumbnail (requires url)
                         mediatype     - Adds the media type of the image
                         metadata      - Lists EXIF metadata for the version of the image
                         archivename   - Adds the file name of the archive version for non-latest versions
                         bitdepth      - Adds the bit depth of the version
                        Values (separate with '|'): timestamp, user, userid, comment, parsedcomment, url, size, dimensions, sha1, mime, thumbmime,
                            mediatype, metadata, archivename, bitdepth
                        Default: timestamp|user
  iilimit             - How many image revisions to return
                        Default: 1
  iistart             - Timestamp to start listing from
  iiend               - Timestamp to stop listing at
  iiurlwidth          - If iiprop=url is set, a URL to an image scaled to this width will be returned.
                        Only the current version of the image can be scaled
                        Default: -1
  iiurlheight         - Similar to iiurlwidth. Cannot be used without iiurlwidth
                        Default: -1
  iimetadataversion   - Version of metadata to use. if 'latest' is specified, use latest version.
                        Defaults to '1' for backwards compatibility
                        Default: 1
  iiurlparam          - A handler specific parameter string. For example, pdf's
                        might use 'page15-100px'. iiurlwidth must be used and be consistent with iiurlparam
                        Default:
  iicontinue          - If the query response includes a continue value, use it here to get another page of results
Examples:
  api.php?action=query&titles=File:Albert%20Einstein%20Head.jpg&prop=imageinfo
  api.php?action=query&titles=File:Test.jpg&prop=imageinfo&iilimit=50&iiend=20071231235959&iiprop=timestamp|user|url
Help page:
  https://www.mediawiki.org/wiki/API:Properties#imageinfo_.2F_ii
* prop=stashimageinfo (sii) *
  Returns image information for stashed images
Parameters:
  siifilekey          - Key that identifies a previous upload that was stashed temporarily.
  siisessionkey       - DEPRECATED! Alias for filekey, for backward compatibility.
  siiprop             - What image information to get:
                        Values (separate with '|'): timestamp, url, size, dimensions, sha1, mime, thumbmime, metadata, bitdepth
                        Default: timestamp|url
  siiurlwidth         - If siiprop=url is set, a URL to an image scaled to this width will be returned.
                        Default: -1
  siiurlheight        - Similar to siiurlwidth. Cannot be used without siiurlwidth
                        Default: -1
  siiurlparam         - A handler specific parameter string. For example, pdf's
                        might use 'page15-100px'. siiurlwidth must be used and be consistent with siiurlparam
                        Default:
Examples:
  api.php?action=query&prop=stashimageinfo&siifilekey=124sd34rsdf567
  api.php?action=query&prop=stashimageinfo&siifilekey=b34edoe3|bceffd4&siiurlwidth=120&siiprop=url
Help page:
* prop=templates (tl) *
  Returns all templates from the given page(s)
Parameters:
  tlnamespace         - Show templates in this namespace(s) only
  tllimit             - How many templates to return
                        Default: 10
  tlcontinue          - When more results are available, use this to continue
  tltemplates         - Only list these templates. Useful for checking whether a certain page uses a certain template.
  tldir               - The direction in which to list
                        Default: ascending
Examples:
  Get templates from the [[Main Page]]::
    api.php?action=query&prop=templates&titles=Main%20Page
  Get information about the template pages in the [[Main Page]]::
    api.php?action=query&generator=templates&titles=Main%20Page&prop=info
  Get templates from the Main Page in the User and Template namespaces::
    api.php?action=query&prop=templates&titles=Main%20Page&tlnamespace=2|10
Help page:
  https://www.mediawiki.org/wiki/API:Properties#templates_.2F_tl
Generator:
* prop=categories (cl) *
  List all categories the page(s) belong to
Parameters:
  clprop              - Which additional properties to get for each category
                         sortkey    - Adds the sortkey (hexadecimal string) and sortkey prefix (human-readable part) for the category
                         timestamp  - Adds timestamp of when the category was added
                         hidden     - Tags categories that are hidden with __HIDDENCAT__
                        Values (separate with '|'): sortkey, timestamp, hidden
  clshow              - Which kind of categories to show
                        Values (separate with '|'): hidden, !hidden
  cllimit             - How many categories to return
                        Default: 10
  clcontinue          - When more results are available, use this to continue
  clcategories        - Only list these categories. Useful for checking whether a certain page is in a certain category
  cldir               - The direction in which to list
                        Default: ascending
Examples:
  Get a list of categories [[Albert Einstein]] belongs to:
    api.php?action=query&prop=categories&titles=Albert%20Einstein
  Get information about all categories used in the [[Albert Einstein]]:
    api.php?action=query&generator=categories&titles=Albert%20Einstein&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Properties#categories_.2F_cl
Generator:
* prop=extlinks (el) *
  Returns all external urls (not interwikies) from the given page(s)
Parameters:
  ellimit             - How many links to return
                        Default: 10
  eloffset            - When more results are available, use this to continue
  elprotocol          - Protocol of the url. If empty and elquery set, the protocol is http.
                        Leave both this and elquery empty to list all external links
                        Can be empty, or One value: http, https, ftp, irc, ircs, gopher, telnet, nntp, worldwind, mailto, news, svn, git, mms
                        Default:
  elquery             - Search string without protocol. Useful for checking whether a certain page contains a certain external url
Example:
  Get a list of external links on the [[Main Page]]:
    api.php?action=query&prop=extlinks&titles=Main%20Page
Help page:
  https://www.mediawiki.org/wiki/API:Properties#extlinks_.2F_el
* prop=categoryinfo (ci) *
  Returns information about the given categories
Parameters:
  cicontinue          - When more results are available, use this to continue
Example:
  api.php?action=query&prop=categoryinfo&titles=Category:Foo|Category:Bar
Help page:
  https://www.mediawiki.org/wiki/API:Properties#categoryinfo_.2F_ci
* prop=duplicatefiles (df) *
  List all files that are duplicates of the given file(s)
Parameters:
  dflimit             - How many files to return
                        Default: 10
  dfcontinue          - When more results are available, use this to continue
  dfdir               - The direction in which to list
                        Default: ascending
Examples:
  api.php?action=query&titles=File:Albert_Einstein_Head.jpg&prop=duplicatefiles
  api.php?action=query&generator=allimages&prop=duplicatefiles
Help page:
  https://www.mediawiki.org/wiki/API:Properties#duplicatefiles_.2F_df
Generator:
* prop=pageprops (pp) *
  Get various properties defined in the page content
Parameters:
  ppcontinue          - When more results are available, use this to continue
  ppprop              - Page prop to look on the page for. Useful for checking whether a certain page uses a certain page prop.
Example:
  api.php?action=query&prop=pageprops&titles=Category:Foo
Help page:
  https://www.mediawiki.org/wiki/API:Properties#pageprops_.2F_pp
--- --- --- --- --- --- --- --- --- --- --- ---  Query: List  --- --- --- --- --- --- --- --- --- --- --- ---
* list=allimages (ai) *
  Enumerate all images sequentially
Parameters:
  aifrom              - The image title to start enumerating from
  aito                - The image title to stop enumerating at
  aiprefix            - Search for all image titles that begin with this value
  aiminsize           - Limit to images with at least this many bytes
  aimaxsize           - Limit to images with at most this many bytes
  ailimit             - How many images in total to return
                        Default: 10
  aidir               - The direction in which to list
                        Default: ascending
  aisha1              - SHA1 hash of image. Overrides aisha1base36
  aisha1base36        - SHA1 hash of image in base 36 (used in MediaWiki)
  aiprop              - What image information to get:
                            mediatype, metadata, bitdepth
  aimime              - What MIME type to search for. e.g. image/jpeg. Disabled in Miser Mode
Examples:
  Array:
    api.php?action=query&list=allimages&aifrom=B
  Array:
    api.php?action=query&generator=allimages&gailimit=4&gaifrom=T&prop=imageinfo
Help page:
  https://www.mediawiki.org/wiki/API:Allimages
Generator:
* list=allpages (ap) *
  Enumerate all pages sequentially in a given namespace
Parameters:
  apfrom              - The page title to start enumerating from
  apto                - The page title to stop enumerating at
  apprefix            - Search for all page titles that begin with this value
  apnamespace         - The namespace to enumerate
                        One value: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
                        Default: 0
  apfilterredir       - Which pages to list
                        One value: all, redirects, nonredirects
                        Default: all
  apminsize           - Limit to pages with at least this many bytes
  apmaxsize           - Limit to pages with at most this many bytes
  apprtype            - Limit to protected pages only
                        Values (separate with '|'): edit, move, upload
  apprlevel           - The protection level (must be used with apprtype= parameter)
                        Can be empty, or Values (separate with '|'): autoconfirmed, sysop
  apprfiltercascade   - Filter protections based on cascadingness (ignored when apprtype isn't set)
                        One value: cascading, noncascading, all
                        Default: all
  aplimit             - How many total pages to return.
                        Default: 10
  apdir               - The direction in which to list
                        Default: ascending
  apfilterlanglinks   - Filter based on whether a page has langlinks
                        One value: withlanglinks, withoutlanglinks, all
                        Default: all
  apprexpiry          - Which protection expiry to filter the page on
                         indefinite - Get only pages with indefinite protection expiry
                         definite - Get only pages with a definite (specific) protection expiry
                         all - Get pages with any protections expiry
                        One value: indefinite, definite, all
                        Default: all
Examples:
  Array:
    api.php?action=query&list=allpages&apfrom=B
  Array:
    api.php?action=query&generator=allpages&gaplimit=4&gapfrom=T&prop=info
  Array:
    api.php?action=query&generator=allpages&gaplimit=2&gapfilterredir=nonredirects&gapfrom=Re&prop=revisions&rvprop=content
Help page:
  https://www.mediawiki.org/wiki/API:Allpages
Generator:
* list=alllinks (al) *
  Enumerate all links that point to a given namespace
Parameters:
  alcontinue          - When more results are available, use this to continue
  alfrom              - The page title to start enumerating from
  alto                - The page title to stop enumerating at
  alprefix            - Search for all page titles that begin with this value
  alunique            - Only show unique links. Cannot be used with generator or alprop=ids
  alprop              - What pieces of information to include
                         ids    - Adds pageid of where the link is from (Cannot be used with alunique)
                         title  - Adds the title of the link
                        Values (separate with '|'): ids, title
                        Default: title
  alnamespace         - The namespace to enumerate
                        Default: 0
  allimit             - How many total links to return
                        Default: 10
Example:
  api.php?action=query&list=alllinks&alunique=&alfrom=B
Help page:
  https://www.mediawiki.org/wiki/API:Alllinks
Generator:
* list=allcategories (ac) *
  Enumerate all categories
Parameters:
  acfrom              - The category to start enumerating from
  acto                - The category to stop enumerating at
  acprefix            - Search for all category titles that begin with this value
  acdir               - Direction to sort in
                        Default: ascending
  acmin               - Minimum number of category members
  acmax               - Maximum number of category members
  aclimit             - How many categories to return
                        Default: 10
  acprop              - Which properties to get
                         size    - Adds number of pages in the category
                        Values (separate with '|'): size, hidden
                        Default:
Examples:
  api.php?action=query&list=allcategories&acprop=size
  api.php?action=query&generator=allcategories&gacprefix=List&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Allcategories
Generator:
* list=allusers (au) *
  Enumerate all registered users
Parameters:
  aufrom              - The user name to start enumerating from
  auto                - The user name to stop enumerating at
  auprefix            - Search for all users that begin with this value
  audir               - Direction to sort in
                        Default: ascending
  augroup             - Limit users to given group name(s)
                        Values (separate with '|'): bot, sysop, bureaucrat
  auexcludegroup      - Exclude users in given group name(s)
  aurights            - Limit users to given right(s)
                        Values (separate with '|'): apihighlimits, autoconfirmed, autopatrol, bigdelete, block, blockemail, bot, browsearchive,
                            createaccount, createpage, createtalk, delete, deletedhistory, deletedtext, deleterevision, edit,
                            editinterface, editusercssjs, editusercss, edituserjs, hideuser, import, importupload,
                            ipblock-exempt, markbotedits, mergehistory, minoredit, move, movefile, move-rootuserpages,
                            move-subpages, nominornewtalk, noratelimit, override-export-depth, patrol, protect, proxyunbannable,
                            purge, read, reupload, reupload-shared, rollback, sendemail, siteadmin, suppressionlog,
                            suppressredirect, suppressrevision, unblockself, undelete, unwatchedpages, upload, upload_by_url,
                            userrights, userrights-interwiki, writeapi
  auprop              - What pieces of information to include.
                         blockinfo      - Adds the information about a current block on the user
                         groups         - Lists groups that the user is in. This uses more server resources and may return fewer results than the limit
                         implicitgroups - Lists all the groups the user is automatically in
                         rights         - Lists rights that the user has
                         editcount      - Adds the edit count of the user
                         registration   - Adds the timestamp of when the user registered if available (may be blank)
                        Values (separate with '|'): blockinfo, groups, implicitgroups, rights, editcount, registration
  aulimit             - How many total user names to return
                        Default: 10
  auwitheditsonly     - Only list users who have made edits
  auactiveusers       - Only list users active in the last 30 days(s)
Example:
  api.php?action=query&list=allusers&aufrom=Y
Help page:
  https://www.mediawiki.org/wiki/API:Allusers
* list=backlinks (bl) *
  Find all pages that link to the given page
Parameters:
  bltitle             - Title to search
                        This parameter is required
  blcontinue          - When more results are available, use this to continue
  blnamespace         - The namespace to enumerate
  blfilterredir       - How to filter for redirects. If set to nonredirects when blredirect is enabled, this is only applied to the second level
                        Default: all
  bllimit             - How many total pages to return. If blredirect is enabled, limit applies to each level separately (which means you may get up to 2 * limit results).
                        Default: 10
  blredirect          - If linking page is a redirect, find all pages that link to that redirect as well. Maximum limit is halved.
Examples:
  api.php?action=query&list=backlinks&bltitle=Main%20Page
  api.php?action=query&generator=backlinks&gbltitle=Main%20Page&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Backlinks
Generator:
* list=blocks (bk) *
  List all blocked users and IP addresses
Parameters:
  bkstart             - The timestamp to start enumerating from
  bkend               - The timestamp to stop enumerating at
  bkdir               - In which direction to enumerate
                         newer          - List oldest first. Note: bkstart has to be before bkend.
                         older          - List newest first (default). Note: bkstart has to be later than bkend.
                        Default: older
  bkids               - Pipe-separated list of block IDs to list (optional)
  bkusers             - Pipe-separated list of users to search for (optional)
  bkip                - Get all blocks applying to this IP or CIDR range, including range blocks.
                        Cannot be used together with bkusers. CIDR ranges broader than /16 are not accepted
  bklimit             - The maximum amount of blocks to list
                        Default: 10
  bkprop              - Which properties to get
                         id         - Adds the ID of the block
                         user       - Adds the username of the blocked user
                         userid     - Adds the user ID of the blocked user
                         by         - Adds the username of the blocking user
                         byid       - Adds the user ID of the blocking user
                         timestamp  - Adds the timestamp of when the block was given
                         expiry     - Adds the timestamp of when the block expires
                         reason     - Adds the reason given for the block
                         range      - Adds the range of IPs affected by the block
                         flags      - Tags the ban with (autoblock, anononly, etc)
                        Values (separate with '|'): id, user, userid, by, byid, timestamp, expiry, reason, range, flags
                        Default: id|user|by|timestamp|expiry|reason|flags
  bkshow              - Show only items that meet this criteria.
                        For example, to see only indefinite blocks on IPs, set bkshow=ip|!temp
                        Values (separate with '|'): account, !account, temp, !temp, ip, !ip, range, !range
Examples:
  api.php?action=query&list=blocks
  api.php?action=query&list=blocks&bkusers=Alice|Bob
Help page:
  https://www.mediawiki.org/wiki/API:Blocks
* list=categorymembers (cm) *
  List all pages in a given category
Parameters:
  cmtitle             - Which category to enumerate (required). Must include Category: prefix. Cannot be used together with cmpageid
  cmpageid            - Page ID of the category to enumerate. Cannot be used together with cmtitle
  cmprop              - What pieces of information to include
                         ids           - Adds the page ID
                         title         - Adds the title and namespace ID of the page
                         sortkey       - Adds the sortkey used for sorting in the category (hexadecimal string)
                         sortkeyprefix - Adds the sortkey prefix used for sorting in the category (human-readable part of the sortkey)
                         type          - Adds the type that the page has been categorised as (page, subcat or file)
                         timestamp     - Adds the timestamp of when the page was included
                        Values (separate with '|'): ids, title, sortkey, sortkeyprefix, type, timestamp
                        Default: ids|title
  cmnamespace         - Only include pages in these namespaces
  cmtype              - What type of category members to include. Ignored when cmsort=timestamp is set
                        Values (separate with '|'): page, subcat, file
                        Default: page|subcat|file
  cmcontinue          - For large categories, give the value retured from previous query
  cmlimit             - The maximum number of pages to return.
                        Default: 10
  cmsort              - Property to sort by
                        One value: sortkey, timestamp
                        Default: sortkey
  cmdir               - In which direction to sort
                        One value: asc, desc
                        Default: asc
  cmstart             - Timestamp to start listing from. Can only be used with cmsort=timestamp
  cmend               - Timestamp to end listing at. Can only be used with cmsort=timestamp
  cmstartsortkey      - Sortkey to start listing from. Must be given in binary format. Can only be used with cmsort=sortkey
  cmendsortkey        - Sortkey to end listing at. Must be given in binary format. Can only be used with cmsort=sortkey
  cmstartsortkeyprefix - Sortkey prefix to start listing from. Can only be used with cmsort=sortkey. Overrides cmstartsortkey
  cmendsortkeyprefix  - Sortkey prefix to end listing BEFORE (not at, if this value occurs it will not be included!). Can only be used with cmsort=sortkey. Overrides cmendsortkey
Examples:
  Get first 10 pages in [[Category:Physics]]:
    api.php?action=query&list=categorymembers&cmtitle=Category:Physics
  Get page info about first 10 pages in [[Category:Physics]]:
    api.php?action=query&generator=categorymembers&gcmtitle=Category:Physics&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Categorymembers
Generator:
* list=deletedrevs (dr) *
  List deleted revisions.
  Operates in three modes:
   1) List deleted revisions for the given title(s), sorted by timestamp
   2) List deleted contributions for the given user, sorted by timestamp (no titles specified)
   3) List all deleted revisions in the given namespace, sorted by title and timestamp (no titles specified, druser not set)
  Certain parameters only apply to some modes and are ignored in others.
  For instance, a parameter marked (1) only applies to mode 1 and is ignored in modes 2 and 3
Parameters:
  drstart             - The timestamp to start enumerating from (1,2)
  drend               - The timestamp to stop enumerating at (1,2)
  drdir               - In which direction to enumerate (1, 3)
                         newer          - List oldest first. Note: drstart has to be before drend.
                         older          - List newest first (default). Note: drstart has to be later than drend.
                        Default: older
  drfrom              - Start listing at this title (3)
  drto                - Stop listing at this title (3)
  drprefix            - Search for all page titles that begin with this value (3)
  drcontinue          - When more results are available, use this to continue (3)
  drunique            - List only one revision for each page (3)
  druser              - Only list revisions by this user
  drexcludeuser       - Don't list revisions by this user
  drnamespace         - Only list pages in this namespace (3)
                        Default: 0
  drlimit             - The maximum amount of revisions to list
                        Default: 10
  drprop              - Which properties to get
                         revid          - Adds the revision ID of the deleted revision
                         parentid       - Adds the revision ID of the previous revision to the page
                         user           - Adds the user who made the revision
                         userid         - Adds the user ID whom made the revision
                         comment        - Adds the comment of the revision
                         parsedcomment  - Adds the parsed comment of the revision
                         minor          - Tags if the revision is minor
                         len            - Adds the length (bytes) of the revision
                         sha1           - Adds the SHA-1 (base 16) of the revision
                         content        - Adds the content of the revision
                         token          - Gives the edit token
                        Values (separate with '|'): revid, parentid, user, userid, comment, parsedcomment, minor, len, sha1, content, token
                        Default: user|comment
Examples:
  List the last deleted revisions of Main Page and Talk:Main Page, with content (mode 1):
    api.php?action=query&list=deletedrevs&titles=Main%20Page|Talk:Main%20Page&drprop=user|comment|content
  List the last 50 deleted contributions by Bob (mode 2):
    api.php?action=query&list=deletedrevs&druser=Bob&drlimit=50
  List the first 50 deleted revisions in the main namespace (mode 3):
    api.php?action=query&list=deletedrevs&drdir=newer&drlimit=50
  List the first 50 deleted pages in the Talk namespace (mode 3)::
    api.php?action=query&list=deletedrevs&drdir=newer&drlimit=50&drnamespace=1&drunique=
Help page:
  https://www.mediawiki.org/wiki/API:Deletedrevs
* list=embeddedin (ei) *
  Find all pages that embed (transclude) the given title
Parameters:
  eititle             - Title to search
  eicontinue          - When more results are available, use this to continue
  einamespace         - The namespace to enumerate
  eifilterredir       - How to filter for redirects
                        Default: all
  eilimit             - How many total pages to return
                        Default: 10
Examples:
  api.php?action=query&list=embeddedin&eititle=Template:Stub
  api.php?action=query&generator=embeddedin&geititle=Template:Stub&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Embeddedin
Generator:
* list=filearchive (fa) *
  Enumerate all deleted files sequentially
Parameters:
  fafrom              - The image title to start enumerating from
  fato                - The image title to stop enumerating at
  faprefix            - Search for all image titles that begin with this value
  falimit             - How many images to return in total
                        Default: 10
  fadir               - The direction in which to list
                        Default: ascending
  fasha1              - SHA1 hash of image. Overrides fasha1base36. Disabled in Miser Mode
  fasha1base36        - SHA1 hash of image in base 36 (used in MediaWiki). Disabled in Miser Mode
  faprop              - What image information to get:
                         user              - Adds user who uploaded the image version
                         description       - Adds description the image version
                         parseddescription - Parse the description on the version
                         mime              - Adds MIME of the image
                        Values (separate with '|'): sha1, timestamp, user, size, dimensions, description, parseddescription, mime, metadata, bitdepth
                        Default: timestamp
Example:
  Array:
    api.php?action=query&list=filearchive
* list=imageusage (iu) *
  Find all pages that use the given image title.
Parameters:
  iutitle             - Title to search
  iucontinue          - When more results are available, use this to continue
  iunamespace         - The namespace to enumerate
  iufilterredir       - How to filter for redirects. If set to nonredirects when iuredirect is enabled, this is only applied to the second level
                        Default: all
  iulimit             - How many total pages to return. If iuredirect is enabled, limit applies to each level separately (which means you may get up to 2 * limit results).
                        Default: 10
  iuredirect          - If linking page is a redirect, find all pages that link to that redirect as well. Maximum limit is halved.
Examples:
  api.php?action=query&generator=imageusage&giutitle=File:Albert%20Einstein%20Head.jpg&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Imageusage
Generator:
* list=iwbacklinks (iwbl) *
  Find all pages that link to the given interwiki link.
  Can be used to find all links with a prefix, or
  all links to a title (with a given prefix).
  Using neither parameter is effectively "All IW Links"
Parameters:
  iwblprefix          - Prefix for the interwiki
  iwbltitle           - Interwiki link to search for. Must be used with iwblprefix
  iwblcontinue        - When more results are available, use this to continue
  iwbllimit           - How many total pages to return
                        Default: 10
  iwblprop            - Which properties to get
                         iwprefix       - Adds the prefix of the interwiki
                         iwtitle        - Adds the title of the interwiki
                        Values (separate with '|'): iwprefix, iwtitle
                        Default:
Examples:
  api.php?action=query&list=iwbacklinks&iwbltitle=Test&iwblprefix=wikibooks
  api.php?action=query&generator=iwbacklinks&giwbltitle=Test&iwblprefix=wikibooks&prop=info
Generator:
* list=langbacklinks (lbl) *
  Find all pages that link to the given language link.
  Can be used to find all links with a language code, or
  all links to a title (with a given language).
  Using neither parameter is effectively "All Language Links"
Parameters:
  lbllang             - Language for the language link
  lbltitle            - Language link to search for. Must be used with lbllang
  lblcontinue         - When more results are available, use this to continue
  lbllimit            - How many total pages to return
                        Default: 10
  lblprop             - Which properties to get
                         lllang         - Adds the language code of the language link
                         lltitle        - Adds the title of the language ink
                        Values (separate with '|'): lllang, lltitle
                        Default:
Examples:
  api.php?action=query&list=langbacklinks&lbltitle=Test&lbllang=fr
  api.php?action=query&generator=langbacklinks&glbltitle=Test&lbllang=fr&prop=info
Generator:
* list=logevents (le) *
  Get events from logs
Parameters:
  leprop              - Which properties to get
                         ids            - Adds the ID of the log event
                         title          - Adds the title of the page for the log event
                         type           - Adds the type of log event
                         user           - Adds the user responsible for the log event
                         userid         - Adds the user ID who was responsible for the log event
                         timestamp      - Adds the timestamp for the event
                         comment        - Adds the comment of the event
                         parsedcomment  - Adds the parsed comment of the event
                         details        - Lists addtional details about the event
                         tags           - Lists tags for the event
                        Values (separate with '|'): ids, title, type, user, userid, timestamp, comment, parsedcomment, details, tags
                        Default: ids|title|type|user|timestamp|comment|details
  letype              - Filter log entries to only this type
                        Can be empty, or One value: block, protect, rights, delete, upload, move, import, patrol, merge, suppress, newusers
  leaction            - Filter log actions to only this type. Overrides letype
                        One value: block/block, block/unblock, block/reblock, protect/protect, protect/modify, protect/unprotect,
                            protect/move_prot, rights/rights, rights/autopromote, upload/upload, upload/overwrite,
                            upload/revert, import/upload, import/interwiki, merge/merge, suppress/block, suppress/reblock
  lestart             - The timestamp to start enumerating from
  leend               - The timestamp to end enumerating
  ledir               - In which direction to enumerate
                         newer          - List oldest first. Note: lestart has to be before leend.
                         older          - List newest first (default). Note: lestart has to be later than leend.
                        Default: older
  leuser              - Filter entries to those made by the given user
  letitle             - Filter entries to those related to a page
  leprefix            - Filter entries that start with this prefix. Disabled in Miser Mode
  letag               - Only list event entries tagged with this tag
  lelimit             - How many total event entries to return
                        Default: 10
Example:
  api.php?action=query&list=logevents
Help page:
  https://www.mediawiki.org/wiki/API:Logevents
* list=recentchanges (rc) *
  Enumerate recent changes
Parameters:
  rcstart             - The timestamp to start enumerating from
  rcend               - The timestamp to end enumerating
  rcdir               - In which direction to enumerate
                         newer          - List oldest first. Note: rcstart has to be before rcend.
                         older          - List newest first (default). Note: rcstart has to be later than rcend.
                        Default: older
  rcnamespace         - Filter log entries to only this namespace(s)
  rcuser              - Only list changes by this user
  rcexcludeuser       - Don't list changes by this user
  rctag               - Only list changes tagged with this tag
  rcprop              - Include additional pieces of information
                         user           - Adds the user responsible for the edit and tags if they are an IP
                         userid         - Adds the user id responsible for the edit
                         comment        - Adds the comment for the edit
                         parsedcomment  - Adds the parsed comment for the edit
                         flags          - Adds flags for the edit
                         timestamp      - Adds timestamp of the edit
                         title          - Adds the page title of the edit
                         ids            - Adds the page ID, recent changes ID and the new and old revision ID
                         sizes          - Adds the new and old page length in bytes
                         redirect       - Tags edit if page is a redirect
                         patrolled      - Tags edits that have been patrolled
                         loginfo        - Adds log information (logid, logtype, etc) to log entries
                         tags           - Lists tags for the entry
                        Values (separate with '|'): user, userid, comment, parsedcomment, flags, timestamp, title, ids, sizes, redirect, patrolled,
                            loginfo, tags
                        Default: title|timestamp|ids
  rctoken             - Which tokens to obtain for each change
                        Values (separate with '|'): patrol
  rcshow              - Show only items that meet this criteria.
                        For example, to see only minor edits done by logged-in users, set rcshow=minor|!anon
                        Values (separate with '|'): minor, !minor, bot, !bot, anon, !anon, redirect, !redirect, patrolled, !patrolled
  rclimit             - How many total changes to return
                        Default: 10
  rctype              - Which types of changes to show
                        Values (separate with '|'): edit, new, log
  rctoponly           - Only list changes which are the latest revision
Example:
  api.php?action=query&list=recentchanges
Help page:
  https://www.mediawiki.org/wiki/API:Recentchanges
Generator:
* list=search (sr) *
  Perform a full text search
Parameters:
  srsearch            - Search for all page titles (or content) that has this value
  srnamespace         - The namespace(s) to enumerate
                        Default: 0
  srwhat              - Search inside the text or titles
                        One value: title, text, nearmatch
  srinfo              - What metadata to return
                        Values (separate with '|'): totalhits, suggestion
                        Default: totalhits|suggestion
  srprop              - What properties to return
                         size             - Adds the size of the page in bytes
                         wordcount        - Adds the word count of the page
                         timestamp        - Adds the timestamp of when the page was last edited
                         score            - Adds the score (if any) from the search engine
                         snippet          - Adds a parsed snippet of the page
                         titlesnippet     - Adds a parsed snippet of the page title
                         redirectsnippet  - Adds a parsed snippet of the redirect title
                         redirecttitle    - Adds the title of the matching redirect
                         sectionsnippet   - Adds a parsed snippet of the matching section title
                         sectiontitle     - Adds the title of the matching section
                         hasrelated       - Indicates whether a related search is available
                        Values (separate with '|'): size, wordcount, timestamp, score, snippet, titlesnippet, redirecttitle, redirectsnippet,
                            sectiontitle, sectionsnippet, hasrelated
                        Default: size|wordcount|timestamp|snippet
  srredirects         - Include redirect pages in the search
  sroffset            - Use this value to continue paging (return by query)
                        Default: 0
  srlimit             - How many total pages to return
                        No more than 50 (500 for bots) allowed
                        Default: 10
Examples:
  api.php?action=query&list=search&srsearch=meaning
  api.php?action=query&list=search&srwhat=text&srsearch=meaning
  api.php?action=query&generator=search&gsrsearch=meaning&prop=info
Help page:
  https://www.mediawiki.org/wiki/API:Search
Generator:
* list=tags (tg) *
  List change tags
Parameters:
  tgcontinue          - When more results are available, use this to continue
  tglimit             - The maximum number of tags to list
                        Default: 10
  tgprop              - Which properties to get
                         name         - Adds name of tag
                         displayname  - Adds system messsage for the tag
                         description  - Adds description of the tag
                         hitcount     - Adds the amount of revisions that have this tag
                        Values (separate with '|'): name, displayname, description, hitcount
                        Default: name
Example:
  api.php?action=query&list=tags&tgprop=displayname|description|hitcount
* list=usercontribs (uc) *
  Get all edits by a user
Parameters:
  uclimit             - The maximum number of contributions to return
                        Default: 10
  ucstart             - The start timestamp to return from
  ucend               - The end timestamp to return to
  uccontinue          - When more results are available, use this to continue
  ucuser              - The users to retrieve contributions for
  ucuserprefix        - Retrieve contibutions for all users whose names begin with this value. Overrides ucuser
  ucdir               - In which direction to enumerate
                         newer          - List oldest first. Note: ucstart has to be before ucend.
                         older          - List newest first (default). Note: ucstart has to be later than ucend.
                        Default: older
  ucnamespace         - Only list contributions in these namespaces
  ucprop              - Include additional pieces of information
                         ids            - Adds the page ID and revision ID
                         timestamp      - Adds the timestamp of the edit
                         comment        - Adds the comment of the edit
                         parsedcomment  - Adds the parsed comment of the edit
                         flags          - Adds flags of the edit
                         patrolled      - Tags patrolled edits
                         tags           - Lists tags for the edit
                        Values (separate with '|'): ids, title, timestamp, comment, parsedcomment, size, flags, patrolled, tags
                        Default: ids|title|timestamp|comment|size|flags
  ucshow              - Show only items that meet this criteria, e.g. non minor edits only: ucshow=!minor
                        NOTE: if ucshow=patrolled or ucshow=!patrolled is set, revisions older than $wgRCMaxAge (7862400) won't be shown
                        Values (separate with '|'): minor, !minor, patrolled, !patrolled
  uctag               - Only list revisions tagged with this tag
  uctoponly           - Only list changes which are the latest revision
Examples:
  api.php?action=query&list=usercontribs&ucuser=YurikBot
  api.php?action=query&list=usercontribs&ucuserprefix=217.121.114.
Help page:
  https://www.mediawiki.org/wiki/API:Usercontribs
* list=watchlist (wl) *
  Get all recent changes to pages in the logged in user's watchlist
Parameters:
  wlallrev            - Include multiple revisions of the same page within given timeframe
  wlstart             - The timestamp to start enumerating from
  wlend               - The timestamp to end enumerating
  wlnamespace         - Filter changes to only the given namespace(s)
  wluser              - Only list changes by this user
  wlexcludeuser       - Don't list changes by this user
  wldir               - In which direction to enumerate
                         newer          - List oldest first. Note: wlstart has to be before wlend.
                         older          - List newest first (default). Note: wlstart has to be later than wlend.
                        Default: older
  wllimit             - How many total results to return per request
                        Default: 10
  wlprop              - Which additional items to get (non-generator mode only).
                         ids                    - Adds revision ids and page ids
                         title                  - Adds title of the page
                         user                   - Adds the user who made the edit
                         userid                 - Adds user id of whom made the edit
                         comment                - Adds comment of the edit
                         parsedcomment          - Adds parsed comment of the edit
                         patrol                 - Tags edits that are patrolled
                         sizes                  - Adds the old and new lengths of the page
                         notificationtimestamp  - Adds timestamp of when the user was last notified about the edit
                         loginfo                - Adds log information where appropriate
                        Values (separate with '|'): ids, title, flags, user, userid, comment, parsedcomment, timestamp, patrol, sizes,
                            notificationtimestamp, loginfo
                        Default: ids|title|flags
  wlshow              - Show only items that meet this criteria.
                        For example, to see only minor edits done by logged-in users, set wlshow=minor|!anon
                        Values (separate with '|'): minor, !minor, bot, !bot, anon, !anon, patrolled, !patrolled
  wlowner             - The name of the user whose watchlist you'd like to access
  wltoken             - Give a security token (settable in preferences) to allow access to another user's watchlist
Examples:
  api.php?action=query&list=watchlist
  api.php?action=query&list=watchlist&wlprop=ids|title|timestamp|user|comment
  api.php?action=query&list=watchlist&wlallrev=&wlprop=ids|title|timestamp|user|comment
  api.php?action=query&generator=watchlist&prop=info
  api.php?action=query&generator=watchlist&gwlallrev=&prop=revisions&rvprop=timestamp|user
  api.php?action=query&list=watchlist&wlowner=Bob_Smith&wltoken=d8d562e9725ea1512894cdab28e5ceebc7f20237
Help page:
  https://www.mediawiki.org/wiki/API:Watchlist
Generator:
* list=watchlistraw (wr) *
  Get all pages on the logged in user's watchlist
Parameters:
  wrcontinue          - When more results are available, use this to continue
  wrnamespace         - Only list pages in the given namespace(s)
  wrlimit             - How many total results to return per request
                        Default: 10
  wrprop              - Which additional properties to get (non-generator mode only)
                         changed  - Adds timestamp of when the user was last notified about the edit
                        Values (separate with '|'): changed
  wrshow              - Only list items that meet these criteria
                        Values (separate with '|'): changed, !changed
  wrowner             - The name of the user whose watchlist you'd like to access
  wrtoken             - Give a security token (settable in preferences) to allow access to another user's watchlist
Examples:
  api.php?action=query&list=watchlistraw
  api.php?action=query&generator=watchlistraw&gwrshow=changed&prop=revisions
Generator:
* list=exturlusage (eu) *
  Enumerate pages that contain a given URL
Parameters:
  euprop              - What pieces of information to include
                         ids    - Adds the ID of page
                         url    - Adds the URL used in the page
                        Values (separate with '|'): ids, title, url
                        Default: ids|title|url
  euoffset            - Used for paging. Use the value returned for "continue"
  euprotocol          - Protocol of the url. If empty and euquery set, the protocol is http.
                        Leave both this and euquery empty to list all external links
                        Default:
  euquery             - Search string without protocol. See [[Special:LinkSearch]]. Leave empty to list all external links
  eunamespace         - The page namespace(s) to enumerate.
  eulimit             - How many pages to return.
                        Default: 10
Example:
  api.php?action=query&list=exturlusage&euquery=www.mediawiki.org
Help page:
  https://www.mediawiki.org/wiki/API:Exturlusage
Generator:
* list=users (us) *
  Get information about a list of users
Parameters:
  usprop              - What pieces of information to include
                          blockinfo      - Tags if the user is blocked, by whom, and for what reason
                          groups         - Lists all the groups the user(s) belongs to
                          implicitgroups - Lists all the groups a user is automatically a member of
                          rights         - Lists all the rights the user(s) has
                          editcount      - Adds the user's edit count
                          registration   - Adds the user's registration timestamp
                          emailable      - Tags if the user can and wants to receive e-mail through [[Special:Emailuser]]
                          gender         - Tags the gender of the user. Returns "male", "female", or "unknown"
                        Values (separate with '|'): blockinfo, groups, implicitgroups, rights, editcount, registration, emailable, gender
  ususers             - A list of users to obtain the same information for
  ustoken             - Which tokens to obtain for each user
                        Values (separate with '|'): userrights
Example:
  api.php?action=query&list=users&ususers=brion|TimStarling&usprop=groups|editcount|gender
Help page:
  https://www.mediawiki.org/wiki/API:Users
* list=random (rn) *
  Get a set of random pages
  NOTE: Pages are listed in a fixed sequence, only the starting point is random. This means that if, for example, "Main Page" is the first
        random page on your list, "List of fictional monkeys" will *always* be second, "List of people on stamps of Vanuatu" third, etc
  NOTE: If the number of pages in the namespace is lower than rnlimit, you will get fewer pages. You will not get the same page twice
Parameters:
  rnnamespace         - Return pages in these namespaces only
  rnlimit             - Limit how many random pages will be returned
                        No more than 10 (20 for bots) allowed
                        Default: 1
  rnredirect          - Load a random redirect instead of a random page
Example:
  api.php?action=query&list=random&rnnamespace=0&rnlimit=2
Generator:
* list=protectedtitles (pt) *
  List all titles protected from creation
Parameters:
  ptnamespace         - Only list titles in these namespaces
  ptlevel             - Only list titles with these protection levels
  ptlimit             - How many total pages to return
                        Default: 10
  ptdir               - In which direction to enumerate
                         newer          - List oldest first. Note: ptstart has to be before ptend.
                         older          - List newest first (default). Note: ptstart has to be later than ptend.
                        Default: older
  ptstart             - Start listing at this protection timestamp
  ptend               - Stop listing at this protection timestamp
  ptprop              - Which properties to get
                         timestamp      - Adds the timestamp of when protection was added
                         user           - Adds the user that added the protection
                         userid         - Adds the user id that added the protection
                         comment        - Adds the comment for the protection
                         parsedcomment  - Adds the parsed comment for the protection
                         expiry         - Adds the timestamp of when the protection will be lifted
                         level          - Adds the protection level
                        Values (separate with '|'): timestamp, user, userid, comment, parsedcomment, expiry, level
                        Default: timestamp|level
Example:
  api.php?action=query&list=protectedtitles
Help page:
  https://www.mediawiki.org/wiki/API:Protectedtitles
Generator:
* list=querypage (qp) *
  Get a list provided by a QueryPage-based special page
Parameters:
  qppage              - The name of the special page. Note, this is case sensitive
                        One value: Ancientpages, BrokenRedirects, Deadendpages, Disambiguations, DoubleRedirects, Listredirects,
                            Lonelypages, Longpages, Mostcategories, Mostimages, Mostlinkedcategories, Mostlinkedtemplates,
                            Mostlinked, Mostrevisions, Fewestrevisions, Shortpages, Uncategorizedcategories, Uncategorizedpages,
                            Uncategorizedimages, Uncategorizedtemplates, Unusedcategories, Unusedimages, Wantedcategories,
                            Wantedfiles, Wantedpages, Wantedtemplates, Unwatchedpages, Unusedtemplates, Withoutinterwiki,
                            Popularpages
  qpoffset            - When more results are available, use this to continue
                        Default: 0
  qplimit             - Number of results to return
                        Default: 10
Example:
  api.php?action=query&list=querypage&qppage=Ancientpages
Generator:
--- --- --- --- --- --- --- --- --- --- --- ---  Query: Meta  --- --- --- --- --- --- --- --- --- --- --- ---
* meta=siteinfo (si) *
  Return general information about the site
Parameters:
  siprop              - Which sysinfo properties to get:
                         general               - Overall system information
                         namespaces            - List of registered namespaces and their canonical names
                         namespacealiases      - List of registered namespace aliases
                         specialpagealiases    - List of special page aliases
                         magicwords            - List of magic words and their aliases
                         statistics            - Returns site statistics
                         interwikimap          - Returns interwiki map (optionally filtered, (optionally localised by using siinlanguagecode))
                         dbrepllag             - Returns database server with the highest replication lag
                         usergroups            - Returns user groups and the associated permissions
                         extensions            - Returns extensions installed on the wiki
                         fileextensions        - Returns list of file extensions allowed to be uploaded
                         rightsinfo            - Returns wiki rights (license) information if available
                         languages             - Returns a list of languages MediaWiki supports (optionally localised by using siinlanguagecode)
                         skins                 - Returns a list of all enabled skins
                         extensiontags         - Returns a list of parser extension tags
                         functionhooks         - Returns a list of parser function hooks
                         showhooks             - Returns a list of all subscribed hooks (contents of $wgHooks)
                        Values (separate with '|'): general, namespaces, namespacealiases, specialpagealiases, magicwords, interwikimap, dbrepllag,
                            statistics, usergroups, extensions, fileextensions, rightsinfo, languages, skins, extensiontags,
                            functionhooks, showhooks
                        Default: general
  sifilteriw          - Return only local or only nonlocal entries of the interwiki map
                        One value: local, !local
  sishowalldb         - List all database servers, not just the one lagging the most
  sinumberingroup     - Lists the number of users in user groups
  siinlanguagecode    - Language code for localised language names (best effort, use CLDR extension)
Examples:
  api.php?action=query&meta=siteinfo&siprop=general|namespaces|namespacealiases|statistics
  api.php?action=query&meta=siteinfo&siprop=interwikimap&sifilteriw=local
  api.php?action=query&meta=siteinfo&siprop=dbrepllag&sishowalldb=
Help page:
  https://www.mediawiki.org/wiki/API:Meta#siteinfo_.2F_si
* meta=userinfo (ui) *
  Get information about the current user
Parameters:
  uiprop              - What pieces of information to include
                          blockinfo        - Tags if the current user is blocked, by whom, and for what reason
                          hasmsg           - Adds a tag "message" if the current user has pending messages
                          groups           - Lists all the groups the current user belongs to
                          implicitgroups   - Lists all the groups the current user is automatically a member of
                          rights           - Lists all the rights the current user has
                          changeablegroups - Lists the groups the current user can add to and remove from
                          options          - Lists all preferences the current user has set
                          preferencestoken - Get a token to change current user's preferences
                          editcount        - Adds the current user's edit count
                          ratelimits       - Lists all rate limits applying to the current user
                          realname         - Adds the user's real name
                          email            - Adds the user's email address and email authentication date
                          acceptlang       - Echoes the Accept-Language header sent by the client in a structured format
                          registrationdate - Adds the user's registration date
                        Values (separate with '|'): blockinfo, hasmsg, groups, implicitgroups, rights, changeablegroups, options, preferencestoken,
                            editcount, ratelimits, email, realname, acceptlang, registrationdate
Examples:
  api.php?action=query&meta=userinfo
  api.php?action=query&meta=userinfo&uiprop=blockinfo|groups|rights|hasmsg
Help page:
  https://www.mediawiki.org/wiki/API:Meta#userinfo_.2F_ui
* meta=allmessages (am) *
  Return messages from this site
Parameters:
  ammessages          - Which messages to output. "*" (default) means all messages
                        Default: *
  amprop              - Which properties to get
                        Values (separate with '|'): default
  amenableparser      - Set to enable parser, will preprocess the wikitext of message
                        Will substitute magic words, handle templates etc.
  amnocontent         - If set, do not include the content of the messages in the output.
  amincludelocal      - Also include local messages, i.e. messages that don't exist in the software but do exist as a MediaWiki: page.
                        This lists all MediaWiki: pages, so it will also list those that aren't 'really' messages such as Common.js
  amargs              - Arguments to be substituted into message
  amfilter            - Return only messages with names that contain this string
  amcustomised        - Return only messages in this customisation state
                        One value: all, modified, unmodified
                        Default: all
  amlang              - Return messages in this language
  amfrom              - Return messages starting at this message
  amto                - Return messages ending at this message
  amtitle             - Page name to use as context when parsing message (for enableparser option)
  amprefix            - Return messages with this prefix
Examples:
  api.php?action=query&meta=allmessages&amprefix=ipb-
  api.php?action=query&meta=allmessages&ammessages=august|mainpage&amlang=de
Help page:
  https://www.mediawiki.org/wiki/API:Meta#allmessages_.2F_am
*** *** *** *** *** *** *** *** *** *** *** *** *** ***  Modules: continuation  *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* action=expandtemplates *
  Expands all templates in wikitext
Parameters:
  title               - Title of page
                        Default: API
  text                - Wikitext to convert
  includecomments     - Whether to include HTML comments in the output
Example:
  api.php?action=expandtemplates&text={{Project:Sandbox}}
Help page:
  https://www.mediawiki.org/wiki/API:Parsing_wikitext#expandtemplates
* action=parse *
  Parses wikitext and returns parser output
Parameters:
  title               - Title of page the text belongs to
                        Default: API
  text                - Wikitext to parse
  summary             - Summary to parse
  page                - Parse the content of this page. Cannot be used together with text and title
  pageid              - Parse the content of this page. Overrides page
  redirects           - If the page or the pageid parameter is set to a redirect, resolve it
  oldid               - Parse the content of this revision. Overrides page and pageid
  prop                - Which pieces of information to get
                         text           - Gives the parsed text of the wikitext
                         langlinks      - Gives the language links in the parsed wikitext
                         categories     - Gives the categories in the parsed wikitext
                         categorieshtml - Gives the HTML version of the categories
                         languageshtml  - Gives the HTML version of the language links
                         links          - Gives the internal links in the parsed wikitext
                         templates      - Gives the templates in the parsed wikitext
                         images         - Gives the images in the parsed wikitext
                         externallinks  - Gives the external links in the parsed wikitext
                         sections       - Gives the sections in the parsed wikitext
                         revid          - Adds the revision ID of the parsed page
                         displaytitle   - Adds the title of the parsed wikitext
                         headitems      - Gives items to put in the <head> of the page
                         headhtml       - Gives parsed <head> of the page
                         iwlinks        - Gives interwiki links in the parsed wikitext
                         wikitext       - Gives the original wikitext that was parsed
                        Values (separate with '|'): text, langlinks, languageshtml, categories, categorieshtml, links, templates, images, externallinks,
                            sections, revid, displaytitle, headitems, headhtml, iwlinks, wikitext
                        Default: text|langlinks|categories|links|templates|images|externallinks|sections|revid|displaytitle
  pst                 - Do a pre-save transform on the input before parsing it
                        Ignored if page, pageid or oldid is used
  onlypst             - Do a pre-save transform (PST) on the input, but don't parse it
                        Returns the same wikitext, after a PST has been applied. Ignored if page, pageid or oldid is used
  uselang             - Which language to parse the request in
  disablepp           - Disable the PP Report from the parser output
Example:
  api.php?action=parse&text={{Project:Sandbox}}
Help page:
  https://www.mediawiki.org/wiki/API:Parsing_wikitext#parse
* action=opensearch *
  Search the wiki using the OpenSearch protocol
Parameters:
  search              - Search string
  limit               - Maximum amount of results to return
                        No more than 100 (100 for bots) allowed
                        Default: 10
  namespace           - Namespaces to search
                        Default: 0
  suggest             - Do nothing if $wgEnableOpenSearchSuggest is false
Example:
  api.php?action=opensearch&search=Te
Help page:
  https://www.mediawiki.org/wiki/API:Opensearch
* action=feedcontributions *
  Returns a user contributions feed
Parameters:
  feedformat          - The format of the feed
                        One value: rss, atom
                        Default: rss
  user                - What users to get the contributions for
  namespace           - What namespace to filter the contributions by
  year                - From year (and earlier)
  month               - From month (and earlier)
  tagfilter           - Filter contributions that have these tags
                        Default:
  deletedonly         - Show only deleted contributions
  toponly             - Only show edits that are latest revisions
  showsizediff        - Show the size difference between revisions. Disabled in Miser Mode
Example:
  api.php?action=feedcontributions&user=Reedy
* action=feedwatchlist *
  Returns a watchlist feed
Parameters:
                        Default: rss
  hours               - List pages modified within this many hours from now
                        The value must be between 1 and 72
                        Default: 24
  wlowner             - The user whose watchlist you want (must be accompanied by wltoken if it's not you)
  wltoken             - Security token that requested user set in their preferences
  wlexcludeuser       - A user whose edits should not be shown in the watchlist
  linktodiffs         - Link to change differences instead of article pages
Examples:
  api.php?action=feedwatchlist
  api.php?action=feedwatchlist&allrev=&linktodiffs=&hours=6
Help page:
  https://www.mediawiki.org/wiki/API:Watchlist_feed
* action=help *
  Display this help screen. Or the help screen for the specified module
Parameters:
  modules             - List of module names (value of the action= parameter)
  querymodules        - List of query module names (value of prop=, meta= or list= parameter)
Examples:
  Whole help page:
    api.php?action=help
  Module (action) help page:
    api.php?action=help&modules=protect
  Query (list) modules help page:
    api.php?action=help&querymodules=categorymembers
  Query (prop) modules help page:
    api.php?action=help&querymodules=info
  Query (meta) modules help page:
    api.php?action=help&querymodules=siteinfo
Help pages:
  https://www.mediawiki.org/wiki/API:Main_page
  https://www.mediawiki.org/wiki/API:FAQ
  https://www.mediawiki.org/wiki/API:Quick_start_guide
* action=paraminfo *
  Obtain information about certain API parameters and errors
Parameters:
                        Values (separate with '|'): block, compare, delete, edit, emailuser, expandtemplates, feedcontributions, feedwatchlist,
                            filerevert, help, import, login, logout, move, opensearch, paraminfo, parse, patrol, protect, purge,
                            query, rollback, rsd, unblock, undelete, upload, userrights, watch
                        Values (separate with '|'): allcategories, allimages, alllinks, allmessages, allpages, allusers, backlinks, blocks, categories,
                            categoryinfo, categorymembers, deletedrevs, duplicatefiles, embeddedin, extlinks, exturlusage,
                            filearchive, imageinfo, images, imageusage, info, iwbacklinks, iwlinks, langbacklinks, langlinks,
                            links, logevents, pageprops, protectedtitles, querypage, random, recentchanges, revisions, search,
                            siteinfo, stashimageinfo, tags, templates, usercontribs, userinfo, users, watchlist, watchlistraw
  mainmodule          - Get information about the main (top-level) module as well
  pagesetmodule       - Get information about the pageset module (providing titles= and friends) as well
  formatmodules       - List of format module names (value of format= parameter)
                        Values (separate with '|'): dbg, dbgfm, dump, dumpfm, json, jsonfm, php, phpfm, rawfm, txt, txtfm, wddx, wddxfm, xml, xmlfm,
                            yaml, yamlfm
Example:
  api.php?action=paraminfo&modules=parse&querymodules=allpages|siteinfo
Help page:
  https://www.mediawiki.org/wiki/API:Parameter_information
* action=rsd *
  Export an RSD (Really Simple Discovery) schema
This module requires read rights
Example:
  api.php?action=rsd
* action=compare *
  Get the difference between 2 pages
  You must pass a revision number or a page title for each part (1 and 2)
Parameters:
  fromtitle           - First title to compare
  fromrev             - First revision to compare
  totitle             - Second title to compare
  torev               - Second revision to compare
Example:
  Create a diff between revision 1 and 2:
    api.php?action=compare&fromrev=1&torev=2
* action=purge *
  Purge the cache for the given titles.
  Requires a POST request if the user is not logged in.
This module requires write rights
Parameters:
  titles              - A list of titles to work on
  pageids             - A list of page IDs to work on
                        Maximum number of values 50 (500 for bots)
  revids              - A list of revision IDs to work on
  forcelinkupdate     - Update the links tables
Example:
  Purge the "Main Page" and the "API" page:
    api.php?action=purge&titles=Main_Page|API
Help page:
  https://www.mediawiki.org/wiki/API:Purge
* action=rollback *
  Undo the last edit to the page. If the last user who edited the page made multiple edits in a row,
  they will all be rolled back
This module only accepts POST requests
Parameters:
  title               - Title of the page you want to rollback.
  user                - Name of the user whose edits are to be rolled back. If set incorrectly, you'll get a badtoken error.
  token               - A rollback token previously retrieved through prop=revisions
  summary             - Custom edit summary. If not set, default summary will be used
  markbot             - Mark the reverted edits and the revert as bot edits
  watchlist           - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch
                        One value: watch, unwatch, preferences, nochange
                        Default: preferences
Examples:
  api.php?action=rollback&title=Main%20Page&user=Catrope&token=123ABC
  api.php?action=rollback&title=Main%20Page&user=217.121.114.116&token=123ABC&summary=Reverting%20vandalism&markbot=1
Help page:
  https://www.mediawiki.org/wiki/API:Rollback
* action=delete *
  Delete a page
Parameters:
  title               - Title of the page you want to delete. Cannot be used together with pageid
  pageid              - Page ID of the page you want to delete. Cannot be used together with title
  token               - A delete token previously retrieved through prop=info
  reason              - Reason for the deletion. If not set, an automatically generated reason will be used
  watch               - DEPRECATED! Add the page to your watchlist
  unwatch             - DEPRECATED! Remove the page from your watchlist
  oldimage            - The name of the old image to delete as provided by iiprop=archivename
Examples:
  Delete the Main Page:
    api.php?action=delete&title=Main%20Page&token=123ABC
  Delete the Main Page with the reason "Preparing for move":
    api.php?action=delete&title=Main%20Page&token=123ABC&reason=Preparing%20for%20move
Help page:
* action=undelete *
  Restore certain revisions of a deleted page. A list of deleted revisions (including timestamps) can be
  retrieved through list=deletedrevs
Parameters:
  title               - Title of the page you want to restore
  token               - An undelete token previously retrieved through list=deletedrevs
  reason              - Reason for restoring (optional)
                        Default:
  timestamps          - Timestamps of the revisions to restore. If not set, all revisions will be restored.
Examples:
  api.php?action=undelete&title=Main%20Page&token=123ABC&reason=Restoring%20main%20page
  api.php?action=undelete&title=Main%20Page&token=123ABC&timestamps=20070703220045|20070702194856
Help page:
  https://www.mediawiki.org/wiki/API:Undelete
* action=protect *
  Change the protection level of a page
Parameters:
  title               - Title of the page you want to (un)protect
  token               - A protect token previously retrieved through prop=info
  protections         - Pipe-separated list of protection levels, formatted action=group (e.g. edit=sysop)
  expiry              - Expiry timestamps. If only one timestamp is set, it'll be used for all protections.
                        Use 'infinite', 'indefinite' or 'never', for a neverexpiring protection.
                        Default: infinite
  reason              - Reason for (un)protecting (optional)
                        Default:
  cascade             - Enable cascading protection (i.e. protect pages included in this page)
                        Ignored if not all protection levels are 'sysop' or 'protect'
  watch               - DEPRECATED! If set, add the page being (un)protected to your watchlist
Examples:
  api.php?action=protect&title=Main%20Page&token=123ABC&protections=edit=sysop|move=sysop&cascade=&expiry=20070901163000|never
  api.php?action=protect&title=Main%20Page&token=123ABC&protections=edit=all|move=all&reason=Lifting%20restrictions
Help page:
* action=block *
  Block a user
Parameters:
  user                - Username, IP address or IP range you want to block
  token               - A block token previously obtained through the gettoken parameter or prop=info
  gettoken            - If set, a block token will be returned, and no other action will be taken
  expiry              - Relative expiry time, e.g. '5 months' or '2 weeks'. If set to 'infinite', 'indefinite' or 'never', the block will never expire.
                        Default: never
  reason              - Reason for block (optional)
  anononly            - Block anonymous users only (i.e. disable anonymous edits for this IP)
  nocreate            - Prevent account creation
  autoblock           - Automatically block the last used IP address, and any subsequent IP addresses they try to login from
  noemail             - Prevent user from sending e-mail through the wiki. (Requires the "blockemail" right.)
  hidename            - Hide the username from the block log. (Requires the "hideuser" right.)
  allowusertalk       - Allow the user to edit their own talk page (depends on $wgBlockAllowsUTEdit)
  reblock             - If the user is already blocked, overwrite the existing block
  watchuser           - Watch the user/IP's user and talk pages
Examples:
  api.php?action=block&user=123.5.5.12&expiry=3%20days&reason=First%20strike
  api.php?action=block&user=Vandal&expiry=never&reason=Vandalism&nocreate=&autoblock=&noemail=
Help page:
* action=unblock *
  Unblock a user
Parameters:
  id                  - ID of the block you want to unblock (obtained through list=blocks). Cannot be used together with user
  user                - Username, IP address or IP range you want to unblock. Cannot be used together with id
  token               - An unblock token previously obtained through the gettoken parameter or prop=info
  gettoken            - If set, an unblock token will be returned, and no other action will be taken
  reason              - Reason for unblock (optional)
Examples:
  api.php?action=unblock&id=105
  api.php?action=unblock&user=Bob&reason=Sorry%20Bob
Help page:
* action=move *
  Move a page
Parameters:
  from                - Title of the page you want to move. Cannot be used together with fromid
  fromid              - Page ID of the page you want to move. Cannot be used together with from
  to                  - Title you want to rename the page to
  token               - A move token previously retrieved through prop=info
  reason              - Reason for the move (optional)
  movetalk            - Move the talk page, if it exists
  movesubpages        - Move subpages, if applicable
  noredirect          - Don't create a redirect
  watch               - DEPRECATED! Add the page and the redirect to your watchlist
  unwatch             - DEPRECATED! Remove the page and the redirect from your watchlist
  ignorewarnings      - Ignore any warnings
Example:
  api.php?action=move&from=Exampel&to=Example&token=123ABC&reason=Misspelled%20title&movetalk=&noredirect=
Help page:
  https://www.mediawiki.org/wiki/API:Move
* action=edit *
  Create and edit pages.
Parameters:
  title               - Page title
  section             - Section number. 0 for the top section, 'new' for a new section
  sectiontitle        - The title for a new section
  text                - Page content
  token               - Edit token. You can get one of these through prop=info.
                        The token should always be sent as the last parameter, or at least, after the text parameter
  summary             - Edit summary. Also section title when section=new
  minor               - Minor edit
  notminor            - Non-minor edit
  bot                 - Mark this edit as bot
  basetimestamp       - Timestamp of the base revision (obtained through prop=revisions&rvprop=timestamp).
                        Used to detect edit conflicts; leave unset to ignore conflicts.
  starttimestamp      - Timestamp when you obtained the edit token.
  recreate            - Override any errors about the article having been deleted in the meantime
  createonly          - Don't edit the page if it exists already
  nocreate            - Throw an error if the page doesn't exist
  md5                 - The MD5 hash of the text parameter, or the prependtext and appendtext parameters concatenated.
                        If set, the edit won't be done unless the hash is correct
  prependtext         - Add this text to the beginning of the page. Overrides text
  appendtext          - Add this text to the end of the page. Overrides text
  undo                - Undo this revision. Overrides text, prependtext and appendtext
  undoafter           - Undo all revisions from undo to this one. If not set, just undo one revision
  redirect            - Automatically resolve redirects
Examples:
  Edit a page (anonymous user):
    api.php?action=edit&title=Test&summary=test%20summary&text=article%20content&basetimestamp=20070824123454&token=%2B\
  Prepend __NOTOC__ to a page (anonymous user):
    api.php?action=edit&title=Test&summary=NOTOC&minor=&prependtext=__NOTOC__%0A&basetimestamp=20070824123454&token=%2B\
  Undo r13579 through r13585 with autosummary (anonymous user):
    api.php?action=edit&title=Test&undo=13585&undoafter=13579&basetimestamp=20070824123454&token=%2B\
Help page:
  https://www.mediawiki.org/wiki/API:Edit
* action=upload *
  Upload a file, or get the status of pending uploads. Several methods are available:
   * Upload file contents directly, using the "file" parameter
   * Have the MediaWiki server fetch a file from a URL, using the "url" parameter
   * Complete an earlier upload that failed due to warnings, using the "filekey" parameter
  Note that the HTTP POST must be done as a file upload (i.e. using multipart/form-data) when
  sending the "file".  Also you must get and send an edit token before doing any upload stuff
Parameters:
  filename            - Target filename
  comment             - Upload comment. Also used as the initial page text for new files if "text" is not specified
                        Default:
  text                - Initial page text for new files
  watch               - DEPRECATED! Watch the page
                        One value: watch, preferences, nochange
  file                - File contents
  url                 - URL to fetch the file from
  filekey             - Key that identifies a previous upload that was stashed temporarily.
  sessionkey          - DEPRECATED! Same as filekey, maintained for backward compatibility.
  stash               - If set, the server will not add the file to the repository and stash it temporarily.
  filesize            - Filesize of entire upload
  offset              - Offset of chunk in bytes
  chunk               - Chunk contents
  asyncdownload       - Make fetching a URL asynchronous
  leavemessage        - If asyncdownload is used, leave a message on the user talk page if finished
  statuskey           - Fetch the upload status for this file key
Examples:
  Upload from a URL:
    api.php?action=upload&filename=Wiki.png&url=http%3A//upload.wikimedia.org/wikipedia/en/b/bc/Wiki.png
  Complete an upload that failed due to warnings:
    api.php?action=upload&filename=Wiki.png&filekey=filekey&ignorewarnings=1
Help page:
  https://www.mediawiki.org/wiki/API:Upload
* action=filerevert *
  Revert a file to an old version
Parameters:
                        Default:
  archivename         - Archive name of the revision to revert to
Example:
  Revert Wiki.png to the version of 20110305152740:
    api.php?action=filerevert&filename=Wiki.png&comment=Revert&archivename=20110305152740!Wiki.png&token=+\
* action=emailuser *
  Email a user.
Parameters:
  target              - User to send email to
  subject             - Subject header
  text                - Mail body
  token               - A token previously acquired via prop=info
  ccme                - Send a copy of this mail to me
Example:
  Send an email to the User "WikiSysop" with the text "Content":
    api.php?action=emailuser&target=WikiSysop&text=Content
Help page:
  https://www.mediawiki.org/wiki/API:E-mail
* action=watch *
  Add or remove a page from/to the current user's watchlist
Parameters:
  title               - The page to (un)watch
  unwatch             - If set the page will be unwatched rather than watched
Examples:
  Watch the page "Main Page":
    api.php?action=watch&title=Main_Page
  Unwatch the page "Main Page":
    api.php?action=watch&title=Main_Page&unwatch=
Help page:
* action=patrol *
  Patrol a page or revision
Parameters:
  token               - Patrol token obtained from list=recentchanges
  rcid                - Recentchanges ID to patrol
Example:
  api.php?action=patrol&token=123abc&rcid=230672766
Help page:
  https://www.mediawiki.org/wiki/API:Patrol
* action=import *
  Import a page from another wiki, or an XML file.
  sending a file for the "xml" parameter.
Parameters:
  token               - Import token obtained through prop=info
  summary             - Import summary
  xml                 - Uploaded XML file
  interwikisource     - For interwiki imports: wiki to import from
                        One value:
  interwikipage       - For interwiki imports: page to import
  fullhistory         - For interwiki imports: import the full history, not just the current version
  templates           - For interwiki imports: import all included templates as well
  namespace           - For interwiki imports: import to this namespace
Example:
  Import [[meta:Help:Parserfunctions]] to namespace 100 with full history:
    api.php?action=import&interwikisource=meta&interwikipage=Help:ParserFunctions&namespace=100&fullhistory=&token=123ABC
Help page:
  https://www.mediawiki.org/wiki/API:Import
* action=userrights *
  Add/remove a user to/from groups
Parameters:
  user                - User name
  add                 - Add the user to these groups
  remove              - Remove the user from these groups
  token               - A userrights token previously retrieved through list=users
  reason              - Reason for the change
                        Default:
Example:
  api.php?action=userrights&user=FooBot&add=bot&remove=sysop|bureaucrat&token=123ABC
Help page:
  https://www.mediawiki.org/wiki/API:User_group_membership
*** *** *** *** *** *** *** *** *** *** *** *** *** ***  Permissions *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* writeapi *
  Use of the write API
Granted to:
  all, user, bot
* apihighlimits *
  Use higher limits in API queries (Slow queries: 500 results; Fast queries: 5000 results). The limits for slow queries also apply to multivalue parameters.
Granted to:
  bot, sysop
*** *** *** *** *** *** *** *** *** *** *** *** *** ***  Formats  *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* format=json *
  Output data in JSON format
Parameters:
  callback            - If specified, wraps the output into a given function call. For safety, all user-specific data will be restricted.
Example:
  Format the query result in the json format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=json
Help page:
  https://www.mediawiki.org/wiki/API:Data_formats
* format=jsonfm *
  Output data in JSON format (pretty-print in HTML)
Parameters:
Example:
  Format the query result in the jsonfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=jsonfm
Help page:
* format=php *
  Output data in serialized PHP format
Example:
  Format the query result in the php format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=php
Help page:
* format=phpfm *
  Output data in serialized PHP format (pretty-print in HTML)
Example:
  Format the query result in the phpfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=phpfm
Help page:
* format=wddx *
  Output data in WDDX format
Example:
  Format the query result in the wddx format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=wddx
Help page:
* format=wddxfm *
  Output data in WDDX format (pretty-print in HTML)
Example:
  Format the query result in the wddxfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=wddxfm
Help page:
* format=xml *
  Output data in XML format
Parameters:
  xmldoublequote      - If specified, double quotes all attributes and content
  xslt                - If specified, adds <xslt> as stylesheet
  includexmlnamespace - If specified, adds an XML namespace
Example:
  Format the query result in the xml format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=xml
Help page:
* format=xmlfm *
  Output data in XML format (pretty-print in HTML)
Parameters:
Example:
  Format the query result in the xmlfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=xmlfm
Help page:
* format=yaml *
  Output data in YAML formatOutput data in JSON format
Parameters:
Example:
  Format the query result in the yaml format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=yaml
Help page:
* format=yamlfm *
  Output data in YAML formatOutput data in JSON format (pretty-print in HTML)
Parameters:
Example:
  Format the query result in the yamlfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=yamlfm
Help page:
* format=rawfm *
  Output data with the debuging elements in JSON format (pretty-print in HTML)
Parameters:
Example:
  Format the query result in the rawfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=rawfm
Help page:
* format=txt *
  Output data in PHP's print_r() format
Example:
  Format the query result in the txt format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=txt
Help page:
* format=txtfm *
  Output data in PHP's print_r() format (pretty-print in HTML)
Example:
  Format the query result in the txtfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=txtfm
Help page:
* format=dbg *
  Output data in PHP's var_export() format
Example:
  Format the query result in the dbg format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=dbg
Help page:
* format=dbgfm *
  Output data in PHP's var_export() format (pretty-print in HTML)
Example:
  Format the query result in the dbgfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=dbgfm
Help page:
* format=dump *
  Output data in PHP's var_dump() format
Example:
  Format the query result in the dump format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=dump
Help page:
* format=dumpfm *
  Output data in PHP's var_dump() format (pretty-print in HTML)
Example:
  Format the query result in the dumpfm format:
    api.php?action=query&meta=siteinfo&siprop=namespaces&format=dumpfm
Help page:
*** Credits: ***
   API developers:
       Roan Kattouw <Firstname>.<Lastname>@gmail.com (lead developer Sep 2007-present)
       Victor Vasiliev - vasilvv at gee mail dot com
       Bryan Tong Minh - bryan . tongminh @ gmail . com
       Sam Reed - sam @ reedyboy . net
       Yuri Astrakhan <Firstname><Lastname>@gmail.com (creator, lead developer Sep 2006-Sep 2007)
   Please send your comments, suggestions and questions to mediawiki-api@lists.wikimedia.org
   or file a bug report at https://bugzilla.wikimedia.org/
</error>
</api>
